84 aero 80 died and won't restart
rush1111
Post by rush1111 »
I was riding and engine slowly died , almost like it ran out of gas, but has plenty.
:coolcruise: TW.
Re: 84 aero 80 died and won't restart
Does the engine spin freely when you try to start it ?
rush1111
Post by rush1111 »
Yes
:coolcruise: TW.
rush1111 wrote: Fri Aug 24, 2018 2:55 amYes
That's good...it's not siezed.
The next logical assumption is: FUEL delivery has become compromised.
Vacuum hose from intake to petcock has failed, split, detached, clogged, etc. ....OR
Fuel hose from petcock to carburetor has failed, clogged, split, detached, etc. ....OR
Screen in the bottom of gas tank has clogged....OR
Float needle has become stuck, or damaged, or clogged with debris such as rust particles,....OR
Debris has infiltrated the bowl and has clogged the main jet and/or the pilot jet....OR
Spark plug has fouled from burning too rich,...OR
Very seldom, but possible : the gas cap on the tank has stopped venting properly and created vacuum
inside the gas tank preventing flow....OR....??
It's not very likely that the spark has failed, but it is possible. Confirm spark when checking for fouled plug.
Good luck sir... :urban:
hondafan
Post by hondafan »
Wondering what was the issue??? Did you figure it out?
