Identify this engine...
SamDavy
Post by SamDavy »
Can anybody identify this engine, my guess is a variated af05e but somebody with more knowledge than me would be greatly appreciated...
Engine
Engine
I own a Honda Eve and a Honda Nifty Fifty.
The Eve has a wiring harness, coils, throttle control and a starter motor from a nifty, since relying on kickstart isn't fun.
bonesv
Re: Identify this engine...
Post by bonesv »
It should have the engine code # stamped on the rear of the motor
harleyracer59
Post by harleyracer59 »
My guess is also variated AF05e. looks like a 2 bolt intake so im saying it's an 85 AF05e from another country that actually got a kicker, or a non USM kicker cover installed. it looks like it has the angled exhaust flange.
:popcorn: Cover looks like ones on more modern motors. Interesting to hear if a late model cover fits on a 2-bolt intake Af05 (spree/Sb50) since it looks quite a bit deeper than the stocker. It could open up options for larger pulleys, clutches and maybe vari’s if the crank and primary shaft will allow.
Pal?
harleyracer59
yup wheelman got it.
search google theres a few pics of this kicker cover. so which way does this go in the spree/ aero debates? don't these have variators?
Deemed too expensive for Honda to bother to certify. Probably better-than-Spree/Elite E for acceleration, but still limited to maybe 3HP.
Wheelman-111 wrote: Mon Nov 26, 2018 5:54 pm limited to maybe 3HP.
Add Taz’s 50mm bore and gears?..hmm
benji
Post by benji »
The big limiting factor on these is the cvt size. Not a very big variator, so not much of a ratio change. Quicker Acceleration I'm sure, but not crazy better. rare as hens teeth over here tho.
