What is the best method to "reset" the air mixture and throttle stop screws of a 1993 Honda Elite 50cc carburetor? I took it apart and cleaned it thoroughly. When I put it back together, I realized I did not document the number of turns of each screw. A rookie mistake!
A thing to note though: the reason I took the carburetor apart is because the scooter was idling fine and could go up to ~10 MPH until it just suddenly dies. It just loses power and die.
So the main question here is: what is the best way to reset the screws on the carburetor?
1993 Honda Elite 50cc Carburetor Screws Reset
Re: 1993 Honda Elite 50cc Carburetor Screws Reset
There is a step-by-step in the Service Manual, but I just set the idle mixture to 1.5 turns out from lightly seated and screw in the throttle stop until it begins to lift the slide a little and fire it up. Idle speed is adjusted to 1800 once running, then twiddle with the mixture screw until highest idle is achieved.
