issues...
oncewaslost1982
issues...
Post by oncewaslost1982 »
Well I am having a couple issues with my spree. I at random times will lose all pulling power and then it will come back on the next run. I have cleaned the carb thoroughly. Also I cannot get the spree to stay idling no matter how high I set the idle. It will just shut off when I slow down to a stop. Any suggestions on either of these will be most appreciated.
uspmale
Post by uspmale »
It's definitely in your idle circuit.
Must be fully removed and whistle clean.
By-starter must also be operational.
Good luck.
oncewaslost1982
idle circuit? Sorry to sound ignorant, what is it? Also, the bike starts fine so the starter is working. What is a bystarter? Thanks for the help. Im learning.
uspmale
Post by uspmale »
What I meant was the idle and choke in the carb. It sounds as if is clogged.
oncewaslost1982
this has an automatic hoke on it doesnt it? What does the choke look like inside the carb? I disassembled the carb and cleaned it before all this started. I dunno. Thanks.
Justin
Skullet
Post by Skullet »
the bystarter is your automatic choke. its the part thats circled in this blow-up of ur carb. :) im a noob at this * too man, and now i have to sell the elite i JUST got licensed so i can buy somethin i can mod. :(
i cleaned my carb first too, but apparently the holes in the adjustment screws (are those the jets?) are too small, u need to clean them out with a wire or somethin really thin. i had to pay a guy $50 to do mine cuz i didnt know what was wrong with it. hope this helps.
MySpree
Post by MySpree »
i rebuild them for cheaper!
Skullet
Post by Skullet »
rebuild what? the carb? thatd be a good deal, but how much would shipping both ways have been? lol.. not to mention being able to pick it up the next day running. ;)
MySpree
Post by MySpree »
yea, i rebuild them not just clean them, i put new floats, gaskets, jets, o rings.
