Dio motor sleeper
Posted: Wed May 22, 2019 11:57 pm
by Rajahdat
What’s up guy.
I’m from Hawaii and wanted to know if any of you guys build any sleeper(quiet and fast) mopeds? Everyone here runs the same thing malossi/polini kit pipe,carb,etc.. just wanted to know if any of you guys got tips for making a quiet and quick moped thanks
Re: Dio motor sleeper
Posted: Thu May 23, 2019 1:16 am
by Meatball
Tall order there...homologated pipes (street legal sound levels) are restrictive and dont produce much power. Also, quiet air filters simply wont provide enough air velocity in the venturi to make use of any other parts. We put the bigger carbs, intakes, reeds, bores and exhausts on there to increase flow as well as providing other scientific improvments to the operational function of a 2-stroke. If you would THEN add a restictive exhaust and air box to make a “sleeper”, the motor would most certainly be....asleep.
Edit: you can make a quiet build, no doubt. It can be a vast improvement over stock, sure, but you’ll get spanked by the loud dio’s easily.
I had to run a stock exhaust for a few weeks on a Corsa build because my Arrow fell apart. It was much quieter but I lost 10mph up top and take-offs were not like before. Still had loud BRAAAP from the air pod I was using and Im sure if I switched to a stock box it wouldve gotten quiet....and even slower.
Posted: Thu May 23, 2019 2:55 am
Great answer Meatball
Posted: Thu May 23, 2019 10:45 am
by bonesv
Swap in a stock gy6 150cc they will never see you com’in
Posted: Mon Jun 10, 2019 11:06 pm
by hondapowersr
Rocking stock pipe because my aarow broke to
it's quiet for sure, but doesn't do this corsa any justice without totally retuning my cvt. Sss is hooking me up with a out of production 2fast pipe can't wait to ditch this stock one again
Posted: Mon Jun 10, 2019 11:54 pm
by Meatball
If its the 2fast pipe Im thinking of...it spanks the Arrow. Say goodbye to sleeper mode tho.
