Spree Stock Exhaust Tip Diameter?
handsomeman
Just got an 86 Spree (verified it is NOT the Iowa Edition). After going through the whole scooter, I discovered that it had the stock jet size (#65) in it but someone cut open the end of the stock exhaust and welded a very large diameter exhaust tip to it. I would like to weld it back to normal size, what is the stock exit hole of a stock Spree exhaust? Thanks!
