sweet parts for a spree check it out!!
darat
Post by darat »
So what's all this stuff?
darat
Post by darat »
it is upgrades for the spree.
burnt_toast
Post by burnt_toast »
looks like some nice upgrades. I don't think the clutch springs will help all that much though, w/ the no low-end torque and all. other stuff looks pretty sweet.
projects galore :nerd:
darat
Post by darat »
the springs will help with takeing off faster
vette76
Post by vette76 »
thats the point. its like if you are driving a manual trans. its like revving the car higher before letting out the clutch.the good thing about this is it doesnt effect top end speed.
87' spree (SOLD
12' wrx
burnt_toast
vette76 wrote:thats the point. its like if you are driving a manual trans. its like revving the car higher before letting out the clutch.the good thing about this is it doesnt effect top end speed.
well mine kinda does this already, since my clutch is pretty worn. :P :lol:
vette76
Post by vette76 »
the clutch shoes wear but so do the springs so it kinda compensates for it.
87' spree (SOLD
12' wrx
darat wrote:it is upgrades for the spree.
So did you buy all this stuff, or is someone selling it? More details please(ie words.)
Comments:
1) Not sure the sock filter will work, but worth a shot.
2) Springs should probably be used in conjuction with heavier centipetal masses, but not sure. Having the clutch catch at higher RPMs just sounds like a good way to wear out the clutch. However, if the torque band is at a higher RPM, this would give you a stronger launch. But at that point I'd also want more clutch pressure to handle the torque, which means heavier masses. I'd do some more research, I'm sure there's a web article on this. Maybe by Polini.
3) What is the coil rated at in ohms? If it doesn't say, what does it measure? Less ohms means it's hotter. Less ohms may also blow the CDI unit if you're not careful. Looks cool though.
vette76
Post by vette76 »
yeah, plus i didnt see anything about it being for an actual spree even tho im sure it would work.(most of the parts)
87' spree (SOLD
12' wrx
darat
Post by darat »
he is selling the parts and it is for a spree i will ask him about the ohms
vette76
Post by vette76 »
do u kno him?
87' spree (SOLD
12' wrx
darat
Post by darat »
no
surfugsto
Post by surfugsto »
those parts are sweet! i just took my engine all apart and i need a new piston, im boring my cylinder out quite a bit... ill need to do some stuff to the carb, those jets look nice
darat
Post by darat »
email the guy and try to get the parts
