Hello fellow rider's i was to share my mock up of my 12 inch stretch for me spree, i wanted something simple and heavy duty so i used....
1/2 by 3 feet of steel cut into 3 bars
1 original spree mount
30 minutes of free time.
Sanding disk grinder
Welder
Easy Peezy Stretch Mount.
ASpreeOfJoy
- BMX
ASpreeOfJoy
- BMX
Re: Easy Peezy Stretch Mount.
Nice
That should be fine.......until you mount up a DIO!!!
Really tho, this looks like a nice and simple stretch-stock-spree mount. Although not everyone has a welder or skills of that nature but one could be found. Thanks for the motivation!!!
You may have to find a different rear fender
ASpreeOfJoy
- BMX
The dio motor would likely pop my welds lol, i have 1 or 2 more bars to add for less flex( if any). Another 1/2 thich for the side with more room and 1/4 inch for the opposing side with the tiny stub on the motor side of the mount. I have a friend who is going to tig what i mock up when that time comes for the dio. Im realy hoping to use my panels, worst case i will heat a razor and trim the bottom to fit. I have to cut the license plate mounts to clear room for the tire. I have some more stuff planned!bonesv wrote: Sat Jun 29, 2019 3:42 pm NiceThat should be fine.......until you mount up a DIO!!!
You may have to find a different rear fender![]()
ASpreeOfJoy
- BMX
Made the mount a little safer by adding some metal as support. I will buy another piece for the left and right sides for more flex proofing. Got it straight enough.
- arrow.jpg (78.85 KiB) Viewed 9927 times
- arrow 2.jpg (158.87 KiB) Viewed 9927 times
RichardUrena
Nice welding work. Let's just hope it holds up. I'm not a good welder so...props to you and your work!
