No Compression after Spree died
Farfignugin
Post by Farfignugin »
So no one complains...'85 Spree
Well, I was driving home tonight and all of a sudden I hear some sort of pop. After that the scoot slowly starts to die and then dies completely. I try to start it and completely no compression (motor turns, but as if spark plug is out). Spark plug is in nice and tight, and the carb & intake are tight too.
Possible causes?
Thanks in advance.
P.S. My dad says it might be the head gasket.
chevyguyjay
Post by chevyguyjay »
sounds like to me u broke a piston ring. no compression, could be the cause. :(
MySpree
Post by MySpree »
yeap, you lost a ring or you have a hole in your piston. make sure that your oil pump is in and that your gaskets and seals are good all around. also, it is possible but unlikely that your reed valve broke.
myhonda
Post by myhonda »
yup i had this happen with my old spree. just as i was gonna pull out the driveway and decided not to fix it cause the case was shot welded together and not realy safe.
Farfignugin
Ok, here is what I found out after taking apart the motor. The top ring is broken and it took some of the piston with it. The good thing is the cylider is completely smooth!
A list of things that I require to fix it follow:
piston
wrist pin
wrist pin clips
rings (upper and lower)
head gasket
cylinder gasket (goes between the crankcase & cylinder)
Does anyone have these on hand? And if so, how much $ for all + shipping. If not, where could I buy?
Thanks in advance!
Farfignugin
Does anyone at least have a set of rings that I could purchase?
wbpolk
Post by wbpolk »
i think MySpree has a site you can buy the parts off. PM him. GL with the rebuild
Or contact Greg at uspmale@yahoo.com
MySpree
Post by MySpree »
i have clips, piston, rings.
Farfignugin
Well I e-mailed Greg, MySpree, what are your prices? I'm looking for good condition stuff at reasonable price.
