Crankshaft threads stripped.. help
ScottsdaleArizona
Post by ScottsdaleArizona »
Hi there .. my face drive came looses and ended up stripping The teeth at the end of the driveshaft.. Im having a hard time finding the correct replacement .. I purchased these 2 ..and they’re not the right part.. the one on the right supposedly is for my 1987 SE50... and it is really close.. only difference is it’s a little thicker .. the variator/boss won’t fit over it... are there 2 different sizes for se50 and maybe se50A? Can I use this one and use the variator with bigger inner diameter? Any help..or advice is welcome ! Thanks
Last edited by ScottsdaleArizona on Wed Nov 27, 2019 6:08 pm, edited 1 time in total.
bonesv
Re: Driveshaft threads stripped.. help
Post by bonesv »
Yea, there's a service manual that can help you identify the correct part(s) of which you would like to know about. That 2nd pic you just posted is of the "crankshaft" and yes those "splines" are stripped. That will be a job for an experienced scooter mechanic and most likely will have to replace the damaged part(crankshaft). This pdf may save you some time. http://hondaspree.net/wiki/index.php5?t ... ce_Manuals
ScottsdaleArizona
Thx
Just can’t find one anywhere .. I’m planning on doing the work myself
Last edited by ScottsdaleArizona on Wed Nov 27, 2019 6:49 pm, edited 1 time in total.
ScottsdaleArizona
Re: Crankshaft threads stripped.. help
Check that: part number I need
13321-gn2-600
bonesv
Post by bonesv »
ScottsdaleArizona wrote: Wed Nov 27, 2019 5:35 pm Thx
I just can’t find one anywhere .. I’m planning on doing the work myself
I don’t recommend you tearing that whole motor apart to replace the crank unless you have done this kind of repair before. You called that part a driveshaft when it was in fact a crankshaft and that tells me something and the reason I recommended a scooter mechanic.
