Honda melody carb adjustment
Hi all, on my 1983 Honda melody's carburetor, at the top is a black plastic pipe with a number 4 on it coming out of the top of it, is there anything underneath this pipe to do with the auto choke? And if so, how can I get it off without damaging it? It seems to be on very tight, I tried to turn it with pliers but stopped because I didn't want to break it, any information would be appreciated
Re: Honda melody carb adjustment
Need pic
I'll take it off and post a picture tomorrow
No need to remove anything. Can snap a few shots while its still installed.
- harleyracer59
melody isn't US market. the only melody ive seen here in the US had some weird choke setup with vacuum hose going to some heater element thing on the cylinder head. US scooters have a different carb that uses an electric auto choke. also us carb was a bigger diameter throat than the jdm melody I worked on.
Yeah I know melody is English, and as I live in Liverpool that works fine! Also I read something about the spree auto choke having wires to it , but that's not the case here , I'll get the picture tomorrow
- harleyracer59
Tinsley68 wrote: Sat Dec 28, 2019 1:34 pm Yeah I know melody is English, and as I live in Liverpool that works fine! Also I read something about the spree auto choke having wires to it , but that's not the case here , I'll get the picture tomorrow
so does yours have the vacuum hoses connecting the carb to the cylinder head or does yours have a cable going to the handle bars to a choke lever?
either way, yes that fitting has to do with your choke. if theres a cable coming from it, it does screw out and there should be a little piston that the cable connects to. when you pull the lever on the handle bar, it raises and lowers this piston to open and close the choke circuit on your carb. if its the vacuum hose type, I have to look for that carb in my garage and get back to you. we swapped the one on the melody for an extra aero carb I had because the aero carb was a larger venturi.
ill look for and check that carb. post some pics and we can compare notes.
Right ok will do, been away for a couple of weeks, but back now, I'll get on to it
When will it be tomorrow ?
