Honda Spree Front Fairing Repair
Posted: Sun Feb 23, 2020 1:48 pm
by 52north
I’m looking for suggestions on how to fix the front fairing on my Spree. The crack is in a location where any reinforcement cannot be hidden on the “back side”.
- BFD18F18-ED41-4671-9DA6-5CC1B64E99DC.jpeg (6.67 KiB) Viewed 8761 times
I’ve tested a couple different epoxies (JB weld-clear weld and Permatex-plastic welder) on a broken front fender. I roughed up and then cleaned the plastic with acetone before applying the epoxy. It seems to me as though the bond broke fairly easy when I tested the fix but maybe this is as good as it gets? Any suggestions on different products or methods I could use?
Re: Honda Spree Front Fairing Repair
Posted: Sun Feb 23, 2020 10:46 pm
by otto-man
After years of trying to find something to repair that type of plastic, the only thing that has worked successfuly for me is to imbed a stainless steel screen "band-aid" into the plastic with a plastic welder. I have two from harbor freight that work pretty good. This process takes a lot of patience and practice, so try repairing on scrap stuff first. Don't over heat. It will distort the back side. Good luck!
Posted: Mon Feb 24, 2020 10:06 am
From what I can tell, the Spree fairings are made of a type of plastic (Polypropylene? Polyethylene??) that until recently NOTHING could bond except for plastic welding as Otto said. I have heard of (but have not explored...) a new-fangled adhesive that bonds these previously non-stickable plastics, perhaps a search is in order. I'd be willing to bet that the stuff will be expensive, but epoxy and polyurethane resins are hopeless.
Posted: Mon Feb 24, 2020 11:23 am
by 52north
otto-man wrote: Sun Feb 23, 2020 10:46 pm
Thanks for the insight. Would you mind posting a picture of the plastic welder you had the most success with?
Thanks
Posted: Mon Feb 24, 2020 11:30 am
by 52north
Wheelman-111 wrote: Mon Feb 24, 2020 10:06 am
I’ll have to look into this. Is the plastic material used in the floor board exactly the same? I’ve got plastic issues.
Posted: Mon Feb 24, 2020 3:22 pm
by Meatball
Thats a pretty sticky spot to repair since the nose cap piece sits in that groove. I would suggest any build-up from the repair be on the inside. Mess up that groove and the nose cap will never sit on there right. Keep us posted on the progress. Ive tried a couple different epoxies and special magical “bonding” compounds with only minimal luck. Some hold longer than others but EVERY single one eventually failed too quickly to deem it a worthy repair.
Posted: Mon Feb 24, 2020 6:25 pm
by otto-man
The one I've had good success with is a "Harbor Freight 80 watt iron plastic welder kit" for $16.99. It has the stainless screen included. Menards and Home Depot also have them. Sorry, for not posting pics (I'm low tech "old school" so loading was a problem). Yes the floor board is the same material. Just remember....Patience and practice. Good luck!
Posted: Wed Feb 26, 2020 7:38 pm
by 52north
I’m just shopping around for a plastic welder. Harbor Freight doesn’t ship to Canada and I can’t find one under $50 up here. Crazy price for a cheap and simple tool.
