elite 125 ignition switch on my aero 50 issues
I’m going insane trying to figure this out lol my aero 50 ignition wires are the exact same as the wiring of the elite 125 ignition switch I bought. Same exact look as the switch that came on my aero which I lost the key. Someone please help because no lights or anything worked when I was done wiring it together. Is it the same or do I need to swap wires around? Or is it another issue? Please help lol gave myself a migraine
- harleyracer59
Re: elite 125 ignition switch on my aero 50 issues
if you have a test light or volt meter. you can troubleshoot it. if not its gonna be trial and error. the scooter wires is what you fork from. red is battery, black is switched power, green is ground, and black with a yellow stripe I believe that's the colors, is the ignition kill wire.
key on= connects red to black. green and black w/yellow stripe are open
key off connects green to black w/yellow stripe. red and black are open.
hope that helps.
hope that helps.
