85 honda spree lost spark
hcornick123
Post by hcornick123 »
I've had my honda spree for a couple years it always ran good. A few days ago it didn't start and there was no spark, so I bought another spark plug came back and it had good spark and so did the old plug. rode it for another day and now it's lost spark altogether. Now we are taking apart and testing electrical with my dads voltmeter. The coil tested within acceptable ranges. When we were doing the cdi terminal plug Red/black----Ground and that was 730 and should be 750-1200. I use the negative battery terminal for my ground and that's where im at now can any one help me get my spark back? Could really use the help thanks.
otto-man
Re: 85 honda spree lost spark
Post by otto-man »
Check for continuity between the blue/yellow and green wire of the pulse coil. Should be 50-200 ohm. Make sure that all wire connections are good.
