is it bad?
is it bad?
to run long trips at full speed? full throtal?
- chevyguyjay
- Farfignugin
- BMX
Re: is it bad?
wot for everrrrrrrmyhonda wrote:to run long trips at full speed? full throtal?
catch me if you can (",)
- Streetglow
- Goped
I end up running at full throttle frequently to make the thing go fast enough to keep up with traffic. I'm considering switching to a BPR7 since they say an 8 works best for 'extended high speed riding'. I would do the 8 but a colder plug typically makes starting more difficult.
each model # is a temperature step
BPR4 Hotter (recommended cold climate)
BPR5 Hot
BPR6 Warm (recommended for normal use)
BPR7 Cold
BPR8 Colder (recommended for high speed riding)
BPR5 Hot
BPR7 Cold
86 Spree (w/neon)
- BMX
- Farfignugin
I don't have any problem starting my scoot with the 8, even in the winter, unless of course it's been sitting for a while (around a week or so).I'm considering switching to a BPR7 since they say an 8 works best for 'extended high speed riding'. I would do the 8 but a colder plug typically makes starting more difficult.
