For my Honda Elite Front Drum brake to Disk brake conversion, I have the NCY Triple tree stem and front legs / gas shocks struts.
Two questions:
1. How far should I insert the shocks / legs / struts in to the tree?
----------There are two allen bolts, and on the legs there is one notch at the top. i was thinking that the top notch on the legs should line up with top bolt (there are two bolts on each side)
2. How much should I torque these bolts?
Thanks!
NCY Shock and tree stem Torque value for Elite Drum to Disk Conversion?
Re: NCY Shock and tree stem Torque value for Elite Drum to Disk Conversion?
The notch on the forks goes up to top bolt and tighten it as if your life depends on it. But don't break itdextermax wrote: Fri Aug 14, 2020 3:50 pm For my Honda Elite Front Drum brake to Disk brake conversion, I have the NCY Triple tree stem and front legs / gas shocks struts.
Two questions:
Thanks!
