Crankcase gasket 86 spree
Lazertits
Post by Lazertits »
Can I use Honda bond? Can’t find a crankcase gasket after replacing my belt. Any help greatly appreciated.
Volvo850R
Re: Crankcase gasket 86 spree
Post by Volvo850R »
I haven’t had a gasket on my belt cover case since i got my spree 5 years ago if that means anything to you
1984 elite ch125
1985 spree nq50
1986 spree nq50
1987 helix cn250
Lazertits
Post by Lazertits »
Volvo850R wrote: Mon Jan 04, 2021 12:07 pm I haven’t had a gasket on my belt cover case since i got my spree 5 years ago if that means anything to you
I sorta had the same thought, thank you for the info!
The gasket is mostly to keep out water and dirt.
Some engines need the gasket for spacing of the starter pinion.
Not Spree though, iirc.
Lazertits
Post by Lazertits »
motormike wrote: Mon Jan 04, 2021 1:14 pm The gasket is mostly to keep out water and dirt.
Thank you for the info!
