Which motor years are interchangeable on the Elite CH80?
timtuff
Post by timtuff »
title. trying to swap out the motor on a late 90s Elite and want to make sure what can be swapped in.
Re: Which motor years are interchangeable on the Elite CH80?
Never swapped any engines in Elite 80, but I have owned several in various years.
The engine was the same all the way through the run from '85 to '07, pretty sure you can swap at will without worry.
motorscooterguide.net mentions some model changes, but says nothing about the engine.
cloick the LINK below for a quick read....good luck and report back with your results please.
https://www.motorscooterguide.net/honda-elite-80-ch80/
whiteGIANT510
Post by whiteGIANT510 »
The only difference is in 85 there was no oil dipstick you fill through a hole with a bolt otherwise all the engines are interchangeable. I even replaced the 85 case half without dipstick with one with dipstick
