Seized front shocks?
Posted: Thu Jan 14, 2021 11:08 pm
by fireblade
So a while ago I got a Honda dio off Facebook marketplace. Bought it off a complete loser. I spent quite a while undoing all the f*cktardery that it had been subjected to. And got it running. It goes pretty well.
But the front forks were seized. I pulled the front wheel off, and only one shock seemed to be seized. So I swapped It out for a spare. But the front forks still didnt work. So i went and got another spare fork, and swapped that in. But it still steers very wooden.
I cant help but wonder if the cast (or forged?) Section that the tubes bolt into could be bent? And maybe 5hats causing the two staunchens to fight each other and bind? There was some damage to the plastics, but the front wheel runs true. (I parted out a dio once, and the front wheel was buckled as all * from an impact)
Any suggestions?
Re: Seized front shocks?
Posted: Fri Jan 15, 2021 2:47 pm
Dismantle. Put a long straight dowel through the bolt holes and see which way they are askew. If it really is the damper unit(s), Ebay has some cheap shock sets labeled for C100 Passport that actually bolt right in to the front end of the SA50 here in US. I'll try to send a link later.
Posted: Sun Jan 17, 2021 10:39 pm
by fireblade
Thanks wheelman.
Posted: Mon Jan 18, 2021 7:47 am
by bonesv
fireblade wrote: Thu Jan 14, 2021 11:08 pm So a while ago I got a Honda dio off Facebook marketplace. Bought it off a complete loser. I spent quite a while undoing all the f*cktardery that it had been subjected to. And got it running. It goes pretty well.
Any suggestions?
This poster is from New Zealand. I believe the dio he spaks of is an SK50 rather than an SA50 and the shocks are different for these two models. This post is also confusing as the poster uses the terms "forks" and "shocks" which can be intrepeted incorrectly. A few pics could prove useful and I should point out that some models of the SK50 are also front disc brake equipped. :surprise:
Posted: Thu Jan 21, 2021 1:08 am
by fireblade
This guy ^ is bang on.
It's a drum brake scoot.
It doesnt look bent. That's the odd thing.
