elite 80 engine in honda spree
nate_lohs
Post by nate_lohs »
hey. i was wondering if anyone has put an elite 80 engine in a honda spree. my buddy has a spree and wants to put a dio in it but he doesnt have the money. i can get an elite 80 engine pretty cheap and i thought id check and see if anyone has ever put one in a spree before.
2001 honda elite S
2006 kawi vulcan 1600
1996 toyota tacoma
myhonda
Post by myhonda »
ive seen pics of it done befor but i asume that there will be welding and electrical work that needs to be done for it to work.
xela_p2004
Post by xela_p2004 »
I believe the motor mounts on the Elite 80 are located on top of the engine versus the dio and spree, motor mounts are located on the bottom of the engine, so thats something to consider.
stillspeeding
Post by stillspeeding »
Its a 4 stroke engine so why bother, in 1983 honda made a 2 stroke aero version but its rare.
Can't afford speed then stay away from it!
HuskieMobileMan
Post by HuskieMobileMan »
My 2 stroke NH80 engine sux compared to a good 50cc engine. No performance mods for it either.
'84 Aero NH125
'84 Aero NH80
'05 Kymco ZX50
KZ250andSpree
Post by KZ250andSpree »
Does anyone have any suggestions for a relatively easy switch motor that will boost the power but still look somewhat stock?
1980 KZ250LTD (need to get it running ><)
1986 Spree
Post by Kenny_McCormic »
there is no easy switch for the stock motor the mounts are different your best bet would be to mod the s*** out of the stock engine
xela_p2004
I disagree with you Kenny, though the motor mounts may have to be slightly modified it is relatively easy to do, and yes there is the issue of relocating the shock mount, but that to is easy. Swaping an Aero 50 motor or Dio is your best bet, the stock motor modified to the bone wont give you the results a Aero 50 or dio motor will give you. I swapped in a Aero 50 motor into my spree and thought at first it seemed difficult it wasn't. I had some help from some of the members here.
If you can get an Aero or Elite 50 engine I'd go that route. I've modded stock Spree engines... if you get an honest 40 MPH from them you're doing really well. You can get much more than that from an Elite 50.
