Cant get my Elite to Start
Dac
Post by Dac »
ok guys i need your help, this has me dumb founded and im getting *
ok so my 92 honda elite 50 wont start. it ran fine one day when i was riding it, stop to go inside and eat and it wouldnt start after that
it has compresion , great spark, new plug, i tore apart my carb. and cleaned that.
what im i missing, every thing is there i dont know why it wont start
when i put my new plug in i kicked it about 5-6 times with out giving it any gas then took the plug back out and it was wet.
i left the plug out over night to let the gas dry and put it all back to gether and still nothing!
im going crazy, what im i missing? i was thinking it was the kill switch (like came unpluged) but then i wouldnt get spark right?
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
MySpree
Post by MySpree »
crank the engine over a couple good times without the spark plug to clean it out, then try and start it, if it doesnt start check your case for oil
Dac
Post by Dac »
ok so just about 5-10 minutes ago i took off my carb. and took it in to a guy i know to clean it out good.
i typed this in school. when i got home i opened the door to my shed and my moped was sitting in gas. there was gas every way from the motor about 3 feet.
something is wrong with the float i believe, the guy who is going to clean it out is also going to fix i think. he said he had the same thing happen with his 4 wheeler.
so he is going to fix that , have the carb. torn apart and boil it in Yamaha racing gas over night , and get me a new air filter. if this dont work im going to go crazy
Dac
Post by Dac »
i know this hole site is about hondas but when taking off the carb on my elite i desided to take the carb. off my yamaha jog to see what it was like...
i think i might now whats wrong with it now but i need some help, since this site is honda only i was thinking is there a site like this for yamaha's?
on a note about the elites carb. it was fully cleaned last night and now parts were order from honda it should be done in 3-4 days i hope.
Dac
f***** going crazy
Post by Dac »
ok so i got the carb back re assembled the whole thing, kicked the damned thing like 400 times and nothing!
its like there is no spark , like its not trying !
i got spark(white blue) i got compression , i got a good pipe, Im losing my mind
Your carb is definitely dirty... your float bowl isn't sealing either, and it doesn't sound like the vacuum-operated petcock is working right (broken.) I'd check to see if you're getting fuel through the vacuum line to the petcock. This will cause flooding.
Also, change your plug, it must be fouled by now.
Dac
Post by Dac »
i took the carb. in and had it cleaned and resembled right at a small engine repair and rebuild shop
ok last night i took out the plug and undid the gas hose ,kicked it about 200 times then put the put it back and i got it running for about 2 minutes the it died because the idle is to low and it wouldn't start again
Then today i went out there and did the same thing and nothing. my step dad decided to put some oil in were the plug goes (not a d*** clue why or how) but it started. i revved the * out of it then took it for a ride, it was kinda slow (like 25-30) but it ran ok. i shut if off then started it right away and it started good. When i was riding there was something rattling like *.
Took it home shut it off, now the only way to get it to start is to put a very little amount of oil in the spark plug hole
my step dad thinks it needs new rings... I have no clue... any one know anything that might help me?
islandbayy
Post by islandbayy »
Probially poor compression/leak. The oil is enough to fill the gap and give enough preassure for it to start. Once it's started, the heat causing the piston to expand enough to keep enough preassure to keep the enigne running. Once it cools, repeat. Probially needs new rings. Take off the cylinder and see if theirs any scoreing.
http://KmanScooters.com
http://MilwaukeeEV.com
Dac
Post by Dac »
well its to late for me to work on it now, but if that is the problem...
is there any way to fix it?
i dont know were i would get rings so is there any way to red-neck it ?
(also thanks, that makes since)
You will need to go to the Honda shop and get new rings. Or go to VTcycles.com and pick up a new jug/piston for $100. Tell them we sent you. You cannot "red neck" a compression issue; you're just going to damage the engine worse as you head to a catastrophic failure.
islandbayy
If it was a 4 stroke engine, you could redkneck it, but in a 2 stroke, as noiseguy said, you'll damage the engine worse.
Dac
Post by Dac »
ok so today i got out side and took the head off, pushed the piston down and it doesn't look bad at all
so i took the (i think its called the jug, having a stupid moment ) and realized my piston is missing a ring!
it should have 2 but it only had one!
im going to call a honda dealer tomorrow and try to order rings. any one know if they still have 92 honda elite 50 sr rings or how much they would cost?
Should be about $30 / set.
If the piston / jug were scored, I'd tell you to buy an aftermarket set. Sounds like you caught this early enough to save it. Well done!
Be careful with the rings; they're cast and very fragile.
Dac
Post by Dac »
ok so i got new rings today for 22$
ill be getting new ones tomorrow...
how do you get the jug over the piston after you put the rings on? They break easy as i learned so how?
im kinda tool-less when it comes to motor stuff like this..
stillspeeding
Post by stillspeeding »
well if you only have one ring on the piston the other one is at the bottom of the case in pieces, its an easy fix for me but you have fun, live & learn!
Can't afford speed then stay away from it!
