1984 Spree Sending Unit only goes to 1/2 tank
Posted: Sun Apr 25, 2021 1:54 pm
by Christophertemple
I have a 1984, when I short the wires out to the gauge it goes to full. But when I have the sending unit out of the tank and hold it all the way up it only goes to half of a tank. Is there a way to fix the sending unit without replacing it?
Re: 1984 Spree Sending Unit only goes to 1/2 tank
Posted: Mon Apr 26, 2021 12:57 pm
You can take the cover off the sending unit and inspect/clean. On an 84-85 Spree, the sender is just a coil of resistance wire, with a wiper attached to the float wire. Make sure all electrical paths are clean - the wiper/resistance wire. Another moving electrical contact is between the pivot of the float wire and spring.
-- One more idea --
The original 2 wire sender may have been replaced with a 3 wire 86/87 Spree sender (with one lead left open). The newer sender also causes a low gauge reading when full. So double check your sender is 2 wire before taking it apart.
3 Wire sender wire colors
Green
Blue/White stripe
Yellow/White stripe
2 Wire sender wire colors
Green
Yellow/White stripe
Posted: Mon Apr 26, 2021 7:13 pm
Good info! Thanks. Yes it appears it has been replaced with a newer 3 wire unit.
So the only way to get this to work correctly is to find a 2 wire sending unit?
Posted: Tue Apr 27, 2021 1:19 pm
...Yes it appears it has been replaced with a newer 3 wire unit.
It it were me, getting a 2 wire sender is where I'd put effort.
I've been only occasionally on this board, Perhaps someone's come up with a simple
circuit to adapt a 3 wire sender to the 2 wire gauge?
-- Fuel Sender info from Service Manual
This details the resistance differences
- Spree_1984_85_Fuel_Sender_Resistance.JPG (46.95 KiB) Viewed 5034 times
