Panel Restoration
Panel Restoration
Doing it the hard way on the old 87 with the body panels. Started sanding all by hand with 220 grit, a razor blade and a Scotch-Brite pad. Then 320, more blade and pad since it had such a rough sand job prior followed by 400 and 500, which is where it is now. Will be seeing 600, 1000 and 1200 before the buff and polish. Very long and labor intensive process, but the results are amazing so far. No deep scrapes and super smooth. Will post pics of the finished product when I get there.
- 20210624_225924.jpg (445.1 KiB) Viewed 41407 times
- 20210624_230033.jpg (385.82 KiB) Viewed 41407 times
Re: Panel Restoration
Nice work, keep me posted on what you are going to use to polish them.
Yep. Did the other panel that way. The pics shows the heat-treated one and the finish sanded (to 1200) one side-by-side. They both need buffed, polished and waxed yet, but I'm pretty pleased with the results so far.
- 20210626_023711.jpg (533.75 KiB) Viewed 41395 times
Decals are on. Since it now has a BBK, I figured the Piston Honda decal was fitting. Some of you fellow old-timers might appreciate that one! LOL
- 20210719_233454.jpg (275.03 KiB) Viewed 41192 times
- 20210719_233341.jpg (545.36 KiB) Viewed 41192 times
I love the Piston Honda logo!
