Dio Af18e small wrist pin what do u think?
Hi new to the site, I just got this 1994 Honda Dio AF18e and trying to install a Malossi MHR 72cc aluminum jug/head piston kit malossi kit# 31 8473. The wrist pin “piston pin” “gudgeon pin” is much larger than one in the bike. 12mm vs possibly 10mm in old piston. What are my options? Malossi Cylinder has same bolt pattern and engine code on rear of case is Af18e 1033811. Thank you for any help. I have to figure out how to post some pics will post them today at some point.
Re: Dio Af18e small wrist pin what do u think?
Call Scooter Swap Shop and chat with those guys. Super cool dudes that are always willing to help out with swaperoo’s like this. Im not sure if theres a thinner small end bearing that will work with the larger wrist pin. Ask them…they would know.
Heres a bearing for using a 10mm wrist pin with a crank that accepts a 12mm. Its simply a thicker bearing. https://scooterswapshop.com/products/st ... 3b89&_ss=r
However, youre trying to go the opposite way and I dont think theres an easy solution. Im leaning towards either a crank swap or using a different top end kit with a 10mm pin. A simple idea would be to use adapter shims in the piston for it to accept the 10mm pin but that would be asking for trouble. They designed the kit with a 12mm for a reason…it needs the strength of a thicker pin. Get a full circle crank with fresh bearings and dont look back.
Get a 12mm crank, if your going bbk it will really let you rev to the moon.
2021 DRZ400sm
2021 DRZ400sm
