Malossi crank part# help
Damdio
Post by Damdio »
Hi, I decided I should go all out with a Malossi crank. I already purchased the mhr aluminum 72cc cylinder kit. I have spit the case, the oem crank is on the bench, trying to verify I’m buying the correct crank . I have searched and still not certain what part # i need. My scooter is a 1994 Dio the engine code on back of the case is AF18E1033811. Also need part # of oem crank bearings and seals. I Don’t want to buy the wrong parts. Thank You for the Help!
ntonar
Re: Malossi crank part# help
Post by ntonar »
Is it a small crank Af18? If so you will need special crank seals, the bearing should be 20x52x12.
Damdio
Post by Damdio »
Ntonar How do I know if it’s small crank or large crank? Do you have a measurement I can take?
ntonar
Post by ntonar »
Easiest way would be to look at the splines that the drive face sits on. I looks like Malossi makes two different cranks one for af18 small spline and one for af16 large spline.
If you have a small spine I would convert it to a large spline. The mag side of the crank should be the same but you will need a smaller seal on the variator side (bearings will be the same as the later dio2 af18 or the af16).
https://scooterswapshop.com/products/ma ... 6775325509
ntonar
Post by ntonar »
Here is a photo of the two styles
Damdio
Post by Damdio »
Thank you 🙏 ntonar
MrJumps
Post by MrJumps »
I had a small end, its worth swapping to the big end, better part selection.
2021 DRZ400sm :worship:
veedubh20
Post by veedubh20 »
the big shaft crank malossi will fit on af18e block . I have special. Size seals use for left side. Af18e for japan block. $30 shipped from Honolulu Hawaii
