85 Honda Spree - petcock issue
Posted: Sun Oct 10, 2021 2:06 pm
Recently acquired a 1985 Honda Spree non-running.
It turns over, has spark, and fuel… too much fuel. Took the carb off and thoroughly cleaned it out, jets and all. Took the reed manifold off and checked the reeds and they are firm, closing back as expected. I did notice the engine case is full of gas though under the reeds.
Took the fuel line off the carb and also the vacuum line. Have a slight drip of fuel from the fuel line and some also from the vacuum line. Applied negative pressure to the vacuum line and very little gas is coming from the fuel line to the carb.
Plan on taking the petcock off the tank, blowing compressed air through the screen and also both lines then down into the top of the petcock per the manual to reset it.
If the petcock is bad after that, where can I find a new one for the 85?
