so i have a 86 aero 50. with the following mods.
malossi bbk
keli variator + koso ride plate . 8.5 g rollers -
s23 slick willy pipe
dual stage reeds + ported intake
- ordered the following contra spring +clutch springs , torsion control pad , 8g rollers and 7.5
im still running the stock carb and filter which i feel is limiting the bbk big time.
will be likely ordering the polini cp 17mm + s23 jet kit pilot and main along with the s23 carb adapter . what im wonder / lost about is how exactly do you setup the throttle cable for it what all is needed to use the stock throttle itself just order the throttle cable from swap shop do i need the 90/45 degree adapter as well ?. i would go with swapshops s23 bundle BUT they only have 19mm/21mm read about some issues on tuning those on the af05e.
aero 50 bbk . polini cp 17 questions !.
