Stock 72 malossi
Stock 72 malossi
I need help tuning my stock 72cc any suggestions
Re: Stock 72 malossi
First you must realize 72cc is not stock.
Besides that, some more information like what scooter, what motor and what other components youve added other than the Malossi.
Hahaha what I meant was by stock 72 is I'm running a 72 malossi with a stock carburetor
Af16e with yellow center spring yellow clutch spring,
The main jet has a 68 in it 10.1 gears
Use a mix of 32:1. Get a CHT gauge and start with 85 mj. If it still runs hot try 90. You are held back to go bigger by carb, intake, filter box, exhaust, etc… and the 72 is getting choked out. Probably needs 105-115 mj but it’ll rich bog unless she can breathe. Best you can do is fatten the mj to the point of bog, back it off a bit and hope its ridable.
Look for a crusing temp around 350-370
370-380 when youre rippin it or hill climbs
390 danger-stop
400 walking
390 danger-stop
400 walking
