hose?
erog5188
hose?
Post by erog5188 »
what does the hose going from the airbox to the back of the belt cover do?, is it necessary or can i put a different air filter on it?
Farfignugin
Post by Farfignugin »
pls post pic, but if I'm thinking right are you talking about the hose that comes from the back (rather inside) of the final reduction case to the rear wheel well/cover thing? If so, that is a vent (so as the oil heats up it doesn't explode or leak from the pressure).
