Replacing bulb 2007 Honda elite
Elitelady99
Post by Elitelady99 »
How do you get the bulb out of a 2007 Honda Elite wiring set up? I was able to get the rest of the handlebar fairing off.
I wiped out and need to see if I broke the bulb or the switch to the headlights. Everything else on the dash works.
Re: Replacing bulb 2007 Honda elite
Elite 80?
I'd guess you pull off the rubber cap (11), then rotate the bulb.
The three fingers on the lamp drop under a flange.
