Engine Stop Switch vs Turning Key
So when I bought my spree the previous owner told me to try to never use the stop switch because you run the risk of messing your automatic starter up. Is there any truth to this? Is it better to use one over the other or are they the exact same and stop switch is just a commodity?
- Spree2.jpg (89.49 KiB) Viewed 6275 times
Re: Engine Stop Switch vs Turning Key
I believe you have been misinformed...
Why would Honda put a stop switch on the scooter if it messed up the starter?
About the only way the stop switch would mess up the starter is if you forget to switch it to “Run”. Then proceed to burn up the starter by trying to start it for 45 minutes.
Ive never cooked a starter by doing this but I have forgotten to flip the switch before.
