loss of power after 10 miles
dougthefisher
Post by dougthefisher »
Hello: I just purchased an 85 Aero 80.
It starts and runs well for about 10 to 15 miles, then bogs out and only idles.
Shut it off for 5 to 10 min., runs fine again.
It has done this twice.
The first time, i pushed it home. This time, I let it cool and made it back.
Any insight would be much appreciated.
Re: lose of power after 10 miles
What is the status of your Aero 80 ?
Is it completely stock, or has it been modified ?
Sounds like a fuel delivery problem.
We have member who is familiar with the Aero 80 intimately.
I will send him a message and try to have him reply here. Member is "Breaze"
Pictured below is the only 80 I've ever owned, and never got it running right.
Aero 80 002.JPG (117.47 KiB) Viewed 13110 times
dougthefisher
Re: loss of power after 10 miles
bone stock
dougthefisher
so I'm thinking its the petcock. there are bubbles in it and a fuel drip in the gas line. fingers crossed. I hope I can find 1
dougthefisher wrote: Wed Dec 14, 2022 12:39 pm so I'm thinking its the petcock. there are bubbles in it and a fuel drip in the gas line. fingers crossed. I hope I can find 1
Very possible and likely that the petcock has suffered damage to the diaphragm due to age. This would explain slow fuel delivery because the petcock will not operate properly when the diaphragm is cracked.
breaze
Post by breaze »
If it's the original peacock, sounds like the problem. Believe it's the 14mm - eBay aftermarket is touch and go - I've got an extra for an 85 with a filter if you need it. Probably should polish the needle valve seat in the carb also to keep fuel level in bowl stable. Make sure fuel cap vent isn't blocked. 10 miles is way past choke concerns but if you suspect it, I can send you a write-up on it.
Good luck
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
breaze
Post by breaze »
I've found this brand to be reliable as far as size listed - 14mm.
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
dougthefisher
thx for the input. the cap is the next step for sure. I ordered this 1 from ebay. fingers crossed
https://www.ebay.com/itm/165590482652
breaze
Post by breaze »
The petcock and carb needle valve work together to level out fuel flow. While you're waiting on petcock, get out a drill, q-tip, and metal polish or toothpaste, and clean that needle seat.
Good luck
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
dougthefisher
yes sir ! will do. thank you
