Hi all,
I have a 1985 honda spree. Recently took off the rear wheel. I am curious as to what the rear torque spec is. Thanks in advance for your help.
Rear Axle Torque Value for 1985 Honda Spree
Andrew
The Spree Guy
"Life would be more fun
if everyone drove a moped"
1985 Honda Spree
- Speed Pulley from SSS
The Spree Guy
1985 Honda Spree
Re: Rear Axle Torque Value for 1985 Honda Spree
Specs are in the FSM available on this board in that section. SA50 is around 60 Ft.-Lbs, likely the same on the Spree. A dab of Blue Loctite and 50 should be fine.
Hey, thanks a bunch Wheelman!
Andrew
The Spree Guy
1985 Honda Spree
The Spree Guy
1985 Honda Spree
