Forgive my lack of technical knowledge, I'm still very much a newbie and don't know a lot about vehicles yet.
I made a post a while ago about a semi-functional scooter I'd bought a few months ago. Everyone who replied to that post was incredibly helpful, and I got a good direction for what my priorities in fixing it up should be. Despite all its issues, it still started up and ran fairly well. Unfortunately, that is no longer the case, and I'm unsure of what's happened. I got into a situation where I left it sitting for approximately three weeks in a shed during a cold snap. Afterwards, my scooter would not start up. The engine is turning over, but not firing, and so is not starting up. I replaced both flat tires (not exactly relevant, but it was something I needed to do on it anyways) and removed, disassembled, and cleaned the carburetor, hoping that maybe it was dirty and that that was the source of the issue. However, it was surprisingly clean it doesn't seem to be, as the problem persists in the same way it did previously.
It had fresh gas and oil in it at the start of the three week inactivity. Is still full on oil and has about 4/5th of the tank full (lots of attempts at getting it to fire seems to have lowered the gas slightly).
Foes anyone have suggestions for this problem? Has anyone else had a similar experience? My next step will be to check the spark plug to make sure it's actually sparking. If that isn't the problem, what could be?
Thank you for reading!
