Just got a MID scorpion for my 72 corsa.
Having a bit of trouble tuning, keeps sputtering/bogging after every jet i throw at it.
MID scorpion tuning
Re: MID scorpion tuning
Verify the pipe doesn't have obstructions inside of it. Be sure the alignment of exhaust flange-gasket-pipe. Is your boost port cut properly. Is timing correct. Be sure reeds are not faulty or damaged.
holddatfaka
everythings aligned and just checked reeds still seem brandnew
bores unported
and how do i check inside the pipe ?
bores unported
When building a motor, I use Hondabond on every single connection except the head. For that I spray copper on it. The 2t is finicky about even the smallest of air leaks. It basically operates like a pump and is dependent on air pressures created inside the case. Drawing air/fuel on the upstroke and blowing exhaust out the pipe on the down. The reeds direct traffic for this but you dont want to be sucking in unregulated air from a leaking connection or blowing exhaust out of a gasket. Internal pressures keep the piston harmonically doing it’s dance.
What jets have you been trying? What carb you got? Stock intake/reeds? What air filter?
holddatfaka
got the pipe running great, went lower on the weights and now it screams!(neighbors hate me)
blew up a koso fan though…
anyone know any fans thatll handle 10-11k+ rpms?
Same happened to me. Fancy “hi-flo” fan came apart at 10k. I put the OEM one back on while I research better fans to get…its been on there for two years now with no issues.
holddatfaka
sounds great, thanks for the info
- burnt_toast
As Meatball already said, stock fan is best 10/10holddatfaka wrote: Sun Apr 09, 2023 1:57 am got the pipe running great, went lower on the weights and now it screams!(neighbors hate me)
projects galore
