Gyro Oil Pump Repair
When oil drains down past the check-ball in the oil pump, what is the proper way to remedy the problem, considering you want to retain the pump in use ?
Re: Gyro Oil Pump Repair
If anyone would know the inner workings of those it would be Dave (mousewheels). I can PM you his number if you want.
Meatball wrote: Mon Apr 24, 2023 4:55 pm If anyone would know the inner workings of those it would be Dave (mousewheels). I can PM you his number if you want.
Yeah, go ahead and share that. I'm not only trying to help a guy in NY with issue, but it looks like my own Gyro has developed similar problem. I've looked at a thread that mousewheels discusses the issue, but have additional questions.
Pm sent
motormike wrote:When oil drains down past the check-ball in the oil pump, what is the proper way to remedy the problem, considering you want to retain the pump in use ?
Pull the check valve (it's a light press fit)
1) Spray from the pump side w/carb cleaner.
Post cleaning test:
Connect the pump side of the valve to the oil tank line (rather than re-assemble the pump)..
Let sit a few days.
2) The above didn't work for the first couple bad check valves I had. So anymore I
always swap in a working check valve. I used Spree oil pumps as a source, but
if you have an Aero 50/Elite 50 pump around I suspect the check valve would also work.
The link below has pics of the Spree/TG60 oil pumps and a teardown of a bad check valve
Link to hondaspree topic
