Will not accelerate over 5mph!!
KissaN50
Post by KissaN50 »
I just bought an 87 NB50, had issues starting, carb removed & cleaned, so that's fixed..the issue now is that it will throttle all the way up, but it will not go anywhere without me pushing off with my feet to build up some momentum, then it will max out at 10mph...WITH me still pushing off when it starts to slow down, that's with the throttle maxed out...if I start it & throttle up while it's on kickstand I notice the front wheel just barely moves, VERY sluggish to start moving & never picks up speed....I was told it could be loose belt🤷 but I'm new to the mechanic-ing stuff, and I don't wanna make it worse or mess something else up by messing with stuff that doesn't need to be messed with 😁, so I thought I'd post here & see if anybody has had this issue or knows what the solution would be...Thank u😁
Re: Will not accelerate over 5mph!!
Belt and/or variator weights and/or clutch
KissaN50
Post by KissaN50 »
Just checked the belt, it's good...& now I'ma golook up variator weights cuz I have absolutely no idea what those are🤣 thank u @motormike
KissaN50 wrote: Thu May 18, 2023 5:47 am ..if I start it & throttle up while it's on kickstand I notice the front wheel just barely moves,
You have confused me with this statement about FRONT wheel....it's the REAR wheel that drives the scooter...it's not a front wheel drive.
rdprentiss
Post by rdprentiss »
Did you ever resolve your problem? I have a similar issue with my 86 Spree. While running fine, it will randomly lose power, then pick back up again. Sometimes it fails to pick back up, and will glide slowly to a stop, with engine dead. The engine will start right back up, and the bike will accelerate as normal for about 3 seconds, then lose all acceleration and barely move the bike at a walking pace. It is as if the governor somehow kicks in and stalls the engine after a few seconds of run. Then, after sitting for a while, half hour or so, it will start and run fine. Am looking for a solution.
