Dio af18 project🔥
zapperaf28
Dio af18 project🔥
Post by zapperaf28 »
Hello, i live in cyprus where we have plenty of dio scooters and this is my second dio I've owned its an af18 and I've decided to document my build this time and let you guys give me advice on everything.
Current project (AF18):
https://i.imgur.com/8nrtYCU.jpg
Previous Project now sold(AF28):
https://i.imgur.com/oEpPjMx.jpg
Parts On the way for the project
(From Scooterattack since im in the EU)
Cylinder kit: Polini Corsa
Exhaust: Scr Corse Handmade for minarelli vertical
Clutch: Motoforce clutch bell and adjustable clutch+ Polini torque spring +15%
Belt: Malossi kevlar drive belt
⬇️(Aliexpress)
Carburetor: Chinese Pwk 24mm with ebay manifold
Gears: 16x42 (9:1)
Koso RPM Gauge and a koso temp gauge
I also ordered some really nice rims from aliexpress along with a 200mm rpm brake kit im gonna fit on the af18. Im going with a (stage6) Black with orange accents for this build, it's going to get painted the following week hopefully🤞.
Some more pics:
Order receipt:
https://i.imgur.com/xFw5qkV.png
Goodies
https://i.imgur.com/sHnyPcq.jpg
Clear tail
https://i.imgur.com/r0QLEyu.jpg
My previous dio (the AF28)
Had a polini contessa with a stage6 clutch and a 21mm phgb carburetor with stock gearing i could do ≈85kmh but it would push the motor to the limits and i also ran a very weird exhaust on it that i have no idea what brand it was, the rpm gauge i had on it used to peak around 10500 RPM but it was kind of overevving.
This is my first upload on a forum ever :confused: sorry if it's hard to read or anything or if you cant access the photos I'll upload elsewhere! Updates to Come.
zapperaf28
Re: Dio af18 project🔥
Sanded down the fairings today, gonna get primed tomorrow. Old sticker adhesive was a pain in the a** :sad:
zapperaf28
Got shipped the wrong carb :x :x got a 34mm instead of a 24mm, ordered a 24mm from a reputable seller near cyprus.
https://i.imgur.com/uufo5HD.jpg
https://i.imgur.com/YOcxU6l.jpg
zapperaf28
Got the rims in the mail today :smile:
https://i.imgur.com/nUZ3XTk.jpg
:rock:
zapperaf28 wrote: Sat Jun 10, 2023 2:27 am Got the rims in the mail today :smile:
zapperaf28
Installed oil pump plug
https://i.imgur.com/CEt7R7H.jpg
Dont know how much gas is in the tank rn so i probably just put way too much 2t in😂 is it gonna be okay?
If it doesnt like your oil mix, it will let you know pretty quick. Too much oil will either be fine, run like crap or not run at all. Its the “not enough oil” that will break stuff. Lol
Be sure to hondabond the heck out of the oil plug before you shove it in. They have o-rings but somehow still leak sometimes.
zapperaf28
Meatball wrote: Mon Jun 12, 2023 4:47 pm If it doesnt like your oil mix, it will let you know pretty quick. Too much oil will either be fine, run like crap or not run at all. Its the “not enough oil” that will break stuff. Lol
Hmm i ordered some loctite quick gasket as hondabond isn't really available in cyprus. The plug fit perfectly i think but when everything finally arrives I'll probably do it
zapperaf28
Got the brake kit in the mail yesterday and put it on the rims, looks pretty cool. But it seems that i need a new spacer :crazy:
https://i.imgur.com/BtrRqnn.jpg
And now im thinking about paint colours for the plastics
Also should the intake on the case be ported for the corsa? This is a jdm af18 dio
Porting isnt necessary to make it rip. The Corsa is amazing for bolt-on and go as is. If you were going to do any porting you’d need to crack open the cases and remove the crank while you do it. Then do the boost port and some other small internal bits while youre in there. Its not worth the effort for complete tear down unless youre doing a crank swap already. If you go that far, port the Corsa itself while youre at it.
zapperaf28
Okay thanks, i won't be swapping the crank anytime soon i don't think, the scooter only has 4k km on it.
When it eventually gives though I'm thinking about an athena crank
zapperaf28
Parts arrived finally
https://i.imgur.com/9ugJLaV.jpg
ntonar
Post by ntonar »
What pipe is that and where did you order it from?
zapperaf28
ntonar wrote: Fri Jun 23, 2023 12:47 pm What pipe is that and where did you order it from?
Just read my initial post, it's an scr corse 70 for minarelli vertical
zapperaf28
https://streamable.com/rglpbp
Is this sound normal? It sounds like scratching, but im pretty sure i lubed up everything, my dad says its the excess oil making that sound. Thanks
