Hi all,
My 2001 Honda Elite S (De-restricted) has been sitting for some time now. When it was running, it ran great. However, I kept having the issue of kick starting it 30+ times before it would actually crank. I gave up for awhile.
I'm back (years later) and looking to get it up and running again...however this time, I'm replacing the head w/ a Polini Corsa and I'd like to replace the carb/other surroundings and need suggestions.
Here is my current setup:
--2001 Honda Elite S (De-restricted)
--Prodigy Variator w/ 9g weights
--De-restricted Exhaust
--Oil Pump Delete
--1.5k Center Clutch Spring
--2k Clutch Grabbers
--.88 Main Jet
--2nd Airbox Tab Removed
--9:1 gears
--49mph GPS confirmed
Any suggestions on a new Carb/Intake that would mate good with the Polini Corsa? (Direct links would be most helpful)
Looking to have it up and running good again. I just think the stock carb was holding it back.
thanks!
2001 Honda Elite S (De-restricted): Aftermarket Carb Suggestions Anyone?
|Prodigy Variator w/ 9g weights|De-restricted Exhaust|Oil Pump Delete|1.5k Center Clutch Spring|2k Clutch Grabbers|.88 Main Jet|2nd Airbox Tab Removed|9:1 gears|49mph GPS confirmed|
Re: 2001 Honda Elite S (De-restricted): Aftermarket Carb Suggestions Anyone?
Unless you are willing to change the intake manifold and run a pod filter, there isn't much that fits in the stock carburetor's snug surroundings. It was about 15 years ago when I found an Amal/Arreche 17.5mm carb that did fit the stock intake and box. You could try searching that with Honda SA and hope somebody still has one. I got mine from a Florida aftermarket supplier, but again it was 2008...
If you plan on keeping the stock bore, keep the stock carb. The bystarter is a neat feature and Keihin is good quality. Youd be hard pressed to find anything that fits as good and matches up with the stock bore as well. Mess with main jets or needles if you need to but keep it. Clean the shít out of it 4 times, buy a rebuild kit for it and run that baby!
First thing I do when I get an old beater thats been sitting for years is get the carb sorted. Replace all the rubber. Bowl gasket, top cap gasket, bystarter o-rings, intake o-rings, etc…also clean every nook and cranny like 3-4 times. Carb cleaner, tiny pipe cleaners, compressed air shot through every hole, etc… its probably the most important piece to make the motor run happy.
Super solid advice^^
I guess I should have been more clear. I have a Polini Corsa that I'm about to install on it. With that said, I'll need an aftermarket Carb, etc.Meatball wrote: Thu Jul 27, 2023 8:05 pm If you plan on keeping the stock bore, keep the stock carb. The bystarter is a neat feature and Keihin is good quality. Youd be hard pressed to find anything that fits as good and matches up with the stock bore as well. Mess with main jets or needles if you need to but keep it. Clean the shít out of it 4 times, buy a rebuild kit for it and run that baby!
Looking to get suggestions on Carb, Intake, Air Filter, etc to go with the Polini Corsa setup.
You have some other things to consider, such as the exhaust pipe you want to use to make this happen. Another thing to consider is what you want to use this for. AND, what, if any, noise restrictions you may have, and to consider all this and make an informed choice to these options or it will be a possible waste of time and money. Ask some questions to this end and you will also find plenty of examples if you read thru this forum and seek the answers thru other peoples experiences. Best of luck and be sure to have unlimited $$$ funds to obtain your goals!W8kbrder wrote: Wed Apr 02, 2025 12:44 pm
