No key or title for Elite E
Posted: Tue Jun 19, 2007 12:48 pm
by jagojago
I picked up a junky old Elite someone was getting rid of and it doesn't have a key. I am wondering if I remove the ignition key cylinder and bring it to Honda will they cut me a key without having proof of ownership? They cut a key for my car but I needed to show them the title. Right now I can't even open the seat to put gas in it.
Also, how can I tell what year the scooter is?
Posted: Tue Jun 19, 2007 2:07 pm
by Kenny_McCormic
you can open the seat by sticking a screwdriver in the slot and turning the seat lock doesnt actully lock. or at least thats how it is on a spree. a dealer might not cut that key but a locksmith will. you can tell the year by looking at the tag riveted to the frame behind the front wheel
Posted: Tue Jun 19, 2007 10:57 pm
by jagojago
Kenny_McCormic wrote:you can open the seat by sticking a screwdriver in the slot and turning the seat lock doesnt actully lock. or at least thats how it is on a spree. a dealer might not cut that key but a locksmith will. you can tell the year by looking at the tag riveted to the frame behind the front wheel
Thanks for the info, the seat opened right up with a screwdriver, I had no idea :D
Now I'm going to try taking the cylinder to the dealer and see if they'll cut me a key.
Posted: Thu Jun 21, 2007 11:22 am
If any key including a screwdriver works on the seat lock, it
may not be helpful in getting a key for the ignition.
The ignition switch does have alpha numeric codes for the key.
Some dealers can cut or order a key from the code.
-- Here's text from a Gyro group...
> I've lost the key to my '86 Gyro. A replacement ignition switch is no
> longer available. Anyone have any ideas on how to solve this dilemma?
Yes. Remove the lock cylinder and look for a code etched/stamped into
it. Take that lock cylinder and that code to your local Honda moto
dealer and they can look it up and cut new keys for you.
Posted: Thu Jun 21, 2007 12:25 pm
by jagojago
mousewheels wrote:If any key including a screwdriver works on the seat lock, it
I meant taking the ignition key cylinder to the dealer, not the dummy seat lock cylinder. Thanks for the info!
Posted: Thu Jun 21, 2007 4:55 pm
by noiseguy
Title issue depends on what state you're in.
