1986 honda spree
1986 honda spree
i got a 86 spree and everything is stock everything runs good goes about 30-31 on flat ground i was wanting to know what would be the best way to make it run faster
well if your getting 30 already the next free/cheap mod is to drill out the exaust it really helps on low end power and launch. you can also file out the intake so there arent any sharp angles in it or put a sb50 intake and reeds on it. modding the intake will also put alot of bottom end power in it and add a little to the topend. you can shave the head up to .020" to increase compression. then you can o the pulley mod this takes away bottom end power and puts it on the topend. Doing all of the mods i just mentioned will get you in the 35-40 mph range.
