Aero Exhaust
Rob406
Aero Exhaust
Post by Rob406 »
Will a Dio or similar exhaust fit an Aero 80?
What models are close?
I can cut and weld. Does not mean i want to take a $200 pipe and chop it to pieces. So i am asking if anyone knows what will fit with minimal modification. Ideally something closer to stock (not looking for all-out race) and also not absurdly loud. The factory pipe is TINY i think it leaves a lot on the table…. Any suggestions?
Rob406
Re: Aero Exhaust
Post by Rob406 »
By the way. Not sure how much activity is on this site. But I cut my stock can open. I first noticed some carbon buildup on the tip. And there was a ton of buildup in the exhaust port in the cylinder. The can was pretty heavy so i wanted to see what was inside. So apparently this glasspack style exhaust hits the back of the can. And then fills it? Somehow finding its way to the second half which dumps out the bottom. The weight turns out to be from all the insulation and perf inside.
So i am wondering if the canister acts as an expansion chamber? I am thinking no and that its strictly for sound … ???
