Fuel tank drain valve
I have a 1989 Honda Elite 50E SB50P, the valve on the gas tank has two fittings coming off it, one is for fuel and the other is for I believe vacuum, how is this valve suppose to work, I blew air in the valve and air comes out, so I'm confused on how it is suppose to work, thank you
Re: Fuel tank drain valve
Vacuum, bro. Suck, not blow.Racer71 wrote: Wed Jan 10, 2024 4:39 pmone is for fuel and the other is for I believe vacuum….. I blew air in…
[/quote]
[/quote]
Yes it is for vacuum and actually, if you have ever cleaned your carburetor and wanted to refill the bowl before kicking that thing 25 times to get it to start, you may have pulled the line off and put it up to your lips and drawn a wee bit of suction to open that valve, it will continue to flow fuel without much vacuum at all it just stays open as long as you don't let off the tube. Not continuous suction just one small initial draw and hold. I just wish the d*** things didn't cost so much when they go bad
[/quote]
