Manual Remote Choke Mod V2.0
- Goped
- Goped
Re: Manual Remote Choke Mod V2.0
- Goped
Can you elaborate on this? What exactly is it doing. Are you bypassing the auto bystarter somehow? Very curious
Pretty sure I watched a youtube of this being done in detailRideslikenacho wrote: Thu May 30, 2024 3:30 pm Can you elaborate on this? What exactly is it doing. Are you bypassing the auto bystarter somehow? Very curious
Here it is........... https://www.youtube.com/watch?v=wBVqOoMwwXI
So is the syringe and extra fuel line to send extra fuel for gard starts or to pull vacuum on the petcock to get fuel flowing to the carb on hard starts?
- Goped
Interesting, so you’re running premix and bypassing that oil injection completely?MINICooperS wrote: Fri May 31, 2024 8:30 pm Strictly occasional cold start when ambient temp is below 72° for any period of time, otherwise not used . . . line goes to previous oil injection port on manifold
I don't run any choke at all in summer
Couldn’t a ‘T’ be added to the vacuum line and have additional hose in same way. Then use syringe to pull a vacuum to open the petcock sooner before battery dies? I tried this with a bulb primer and no luck, the syringe though might do it.
