114 stroker build
scootfast
114 stroker build
Post by scootfast »
Looking for any tips on keeping an air cooled stroker cool. Any tips or tricks would be very helpful. Thanks all.
bonesv
Re: 114 stroker build
Post by bonesv »
You could get one of those water-cooled cylinder heads I have seen around and have it ground to match up with your bore, and then you need a radiator and some coolant hose, etc. so there's a suggestion for you. I would do some research and talk to some people who have personal experience with those heads to help make a decision whether or not to invest in that. I don't have any experience myself but I have wondered if they would help a lot or just a little. Then you could let us know!
Fat jetting or cobbling together a shroud to fit around the jug would help with the temps. Maybe a fan scoop also. I built a 50x50 and didnt have any cooling issues once I finally dialed in the tune. I know the fatty air-cooled strokers 120-130cc suffer from heat issues and can only run wot for short periods. The water-cooled stuff can run all day at full scream with no worries of meltdown…properly tuned of course.
My buddy built a water-cooled setup using a heater core from an old Datsun in his back yard. Bought a cheap 12v water pump on ebay and plumbed it with garden hose. Total backwoods redneck build but it worked and that scooter was an absolute ripper.
burnt_toast
Post by burnt_toast »
Meatball wrote: Wed Apr 03, 2024 1:25 am Fat jetting or cobbling together a shroud to fit around the jug would help with the temps. Maybe a fan scoop also. I built a 50x50 and didnt have any cooling issues once I finally dialed in the tune. I know the fatty air-cooled strokers 120-130cc suffer from heat issues and can only run wot for short periods. The water-cooled stuff can run all day at full scream with no worries of meltdown…properly tuned of course.
Love this!! :twisted:
Can attest to the 120cc stroker heat issues.. Built one for 1/8mi off road drag racing. Did great, but never finished tuning it for street. WOT jumping onto highway for a few mi. killed it
projects galore :nerd:
