Replacing carb on '86 Honda Spree NQ50 but the new part is different?
Posted: Tue Apr 23, 2024 10:02 am
by tastier
Total noob here, but I bought a replacement carburetor for my '86 Spree on ebay from a reputable seller. Double checked the year and model just to make sure. However, the new carb is different and I'm not 100% sure how to hook it up!
I marked three spots on the new carb with arrows that look like they need a hose attached. The top one (with the black covering) looks like maybe that doesn't get attached anyway? And the one on the bottom with the hose attached - that one doesn't have anything hooked up on my current carb. The one on the top-right, I have no idea.
Any ideas are appreciated (or maybe I just got the wrong part?). OR am I better off just cleaning the current carb (yet again) instead of replacing?
Re: Replacing carb on '86 Honda Spree NQ50 but the new part is different?
Posted: Wed Apr 24, 2024 2:58 am
by MINICooperS
Yes, you have the wrong carb and obviously a china-clone . . . I vote for keeping your OEM carb but perhaps you can post pics of the OEM off the bike assembled and then more pics after it's taken apart? Carb "cleaning" means different things to different people.
btw . . . why did you buy a replacement? If you plan on running a bystarter, those old bare wires look suspect.
Posted: Wed Apr 24, 2024 9:25 am
by tastier
Thanks. Yeah every spring it doesn't start and I end up cleaning the carb (probably because I was using fuel with some ethanol in it?). IDK, it'll run for a summer and then not start again. I figured a "clean" carb would solve my problem, but probably will just introduce more problems.
Yeah I'm also concerned about those wires (the electric starter doesn't work, maybe that's why!)
Posted: Thu May 02, 2024 8:04 pm
Yes the bystarter is on the wrong side of the venturi. It's for an Aero or Elite.
Posted: Thu Oct 31, 2024 8:40 pm
Try using some Staybil in the gas in the fall before you put it up for the winter. Add the Staybil then run it for about a half an hour the fill it up and add some more Staybil and you will be better off as I never have this problem with any scooter or ATV.
