Malossi afr gauge help
Posted: Sun Apr 28, 2024 3:09 pm
by Caspervolas
Just got a malossi rapid sense afr gauge, I know it’s for 4 strokes but it should work on 2 stroke it will just reduce the life of the sensor. Has anyone used one of these? I don’t get any readings at all.
Thanks,
Casper
Re: Malossi afr gauge help
Posted: Mon Apr 29, 2024 10:37 am
by bonesv
You use that gauge on what scooter? I think you need to connect it to a power source after the key switch. Then just turn on the ignition and it should show it's working. I don't know how it is connected so you're on your own there
Posted: Mon Apr 29, 2024 6:38 pm
by Meatball
Someone used an afr on their 2t years ago and it was mega lean when tuned to 14.7. Sounded real zingy and ran like a raped ape….then burned a hole in his piston. Maybe he chose the wrong mounting spot on his exhaust since they have separate internal chambers or maybe its just a bad idea entirely. I tune with reading the sparkplug, monitoring the cht gauge, throttle response and sound. Using those 4 things gives you a pretty clear picture where your jets are at.
Posted: Wed May 08, 2024 12:18 pm
by Caspervolas
Yeah I don’t think it’s gonna work, learning experience I guess. They make ones for 2 stroke but they are super expensive and I’m good on that.
