Starter engages without brake lever or start button
Posted: Mon Sep 09, 2024 9:29 pm
by Rideslikenacho
Tried jumping the bike off with cables due to bad battery and no kickstarter. Normally this would work, however the starter engages without the brake lever or start button pushed. The fuse looks fine and everything else worked fine prior. Recently had the dead starter and found the broken wire close to the loop end and fixed that. Any ideas? I thought maybe it is the starter button is fried but then the brake lever control would also need to be fried too which seems odd.
Re: Starter engages without brake lever or start button
Posted: Mon Sep 09, 2024 10:53 pm
by bonesv
Wires might be crossed or ignition switch may be compromised?
Posted: Tue Sep 10, 2024 9:54 pm
by Rideslikenacho
I’m wondering if the starter button, ignition or brake switches have gone bad somehow. Worked fine before though so not sure.
Posted: Thu Sep 12, 2024 11:57 am
I've had same thing happen and the fix was a new key switch...in my case.
Good luck sir...motor
Posted: Fri Sep 13, 2024 8:27 am
by Rideslikenacho
Thank you sir I will swap one with a known good one and see what happens.
