Honda Dio (AF27) charging system test?
fireblade
Post by fireblade »
Hi team,
I did a search, but couldn't find a testing flow chart for the charging system.
My AF27 doesn't charge. The voltage at the battery doesn't increase when the engine is running/the engine revs increase.
On a longer ride the battery slowly discharges until the lights and turn signals completely stop working.
Can somebody please tell me which wires/what to test to identify which component is faulty?
Thanks in advance.
HONDA NQ50 "FIREBLADE"
bonesv
Re: Honda Dio (AF27) charging system test?
Post by bonesv »
FIRST QUESTION: Does the headlight work when it's running?
The turn sig's and brake light(s) work on battery but, headlight runs off of the lighting(alternator) side of the system. The voltage regulator and rectifier should also be tested to verify they are working properly. Definitely check that the ground is cleanly connected to the block (located under lower starter bolt) and that the bolt is tight. Questions: (1) Has any repair work been done recently? or has anyone changed out any parts recently? (2) Has your scooter been sitting and not running for any long period of time? (one month or longer) (3) Has anyone besides yourself ridden your scooter recently? (4) Is your scooter completely stock? (not modified and no aftermarket parts of any kind)? Please give pertinent answers :thumbsup:
file:///C:/Users/aztec/Downloads/SA50_88-02_service%20(1).pdf
Go to section 14 and read up on this.....
fireblade
Post by fireblade »
Hey, thanks for your reply Bonesv!
That file isn't click-able?
I probably won't get to do any testing until this weekend coming.
fireblade
Post by fireblade »
Hey BonesV,
That files not click able?
The weekend is here, and I wanna do the testing.
bonesv
Post by bonesv »
fireblade wrote: Thu Apr 17, 2025 12:18 am Hey BonesV,
Try this viewtopic.php?f=11&t=12668
Look in Charging system
