weight roller honda elite 50 lx, 1989
kosta
Post by kosta »
Hello,
does anybody know the weight of the stock/ original roller in vario for honda elite s50lx, year 1989?
Number honda is 22121GR1010.
Thanks for infos,
Konstantin
bonesv
Re: weight roller honda elite 50 lx, 1989
Post by bonesv »
Those are the AF05 motor and I believe they use 9 or 10 gram roller weights so there are 6 of them and the size is 16 X 13 and should come as a set from many different sellers. I have found them at a place called Treatland.tv and they always have a good selection and different brands like https://www.treatland.tv/polini-rollers ... 42.063.htm and https://www.treatland.tv/malossi-16x13- ... 9823p0.htm then some less expensive ones are https://www.treatland.tv/athena-16-x-13 ... eights.htm and of course these sliding ones which are a little different and need to be a little less heavy https://www.treatland.tv/dr-pulley-16-x ... ollers.htm I think the Athena are suitable for the money and if you get a couple different weight sizes you can experiment. Just be careful when you remove and install the nut on the crankshaft because if you strip the threads real bad, it can cost you a new crank!!! Take your time.
kosta
Post by kosta »
Thanks a lot for answering, bonesv. Helped choosing.
I took this: https://www.easyparts-rollerteile.de/Va ... -p33544750 and also a belt : https://www.easyparts-rollerteile.de/Ke ... -p33544653
I live in Germany-so take the shops here.
I was thinking abot little longer (5-10mm) and wider (1mm) belt, for little more top speed. Helped at my Lead NH80 (similar to your Aero 80).
But needs some time at start to get rpm.
So did not, my Elite is stock, too weak for that maybe.
Will see tomorrow, if new belt gives me a LITTLE more speed, when time for changing.
Greetings Konstantin
bonesv
Post by bonesv »
Whoops! I didn't notice your location in your signature. Glad you found everything you need and it was my pleasure to have helped! You know what you are doing and I will look for your returns to post up new info! Auf Wiedersehen!
